OK you speaker gurus, when replacing the rotted foam material inside a speaker cabinet, is there an advantage of replacing with foam material or is fiberglass insulation just as good.
I was given a pair of Powered Advents that didn't work but I have them up and singing now.:yes:
Someone had been inside these already and left a few crumbs of the original foam left inside the cabinet.
I can probably get some insulation for free but I wouldn't mind buying acoustical foam if it is actually better.
Thanks for any suggestions :thmbsp:
