Parallax982
Well, many of you guys guided me down this rabbit hole after I found the Rotel 1100Q for $25. Was a journey of rediscovery and now I'm hooked. Turns out the WOW on that thing is messed up. The belt is new and well adjusted, everything's lubed, and the culprit is the motor. At some point I may fix it. Or maybe not. I could just steel the dust cover, which is a bit wide but otherwise fits the Thorens TD-160 I picked up today.
It's in serviceable condition for $300. Seems to run well. When I checked the WOW with my phone app, I was getting 0.34% but I've not checked the belt, the pulley or oiled the bearing. Also, it was taken with a phone so it may not be accurate. It has a spliced power cord so I'll need to replace it. Had it plugged in and spinning earlier but not a great idea to run it that way long term. The platter does not switch from 33 to 45, so that indicates a need for servicing. Not that I plan to play 45s. In any event, a Thorens is well worth a bit of maintenance and I got it for $300 so I expected to spend a bit to bring it up to speed.
It has a Stanton 600 cartridge. What do you think of that cartridge? If it's decent, which stylus would you recommend? This time I'm going to invest in a new stylus.
I have the Realistic 1000E cartridge made by Shure attached to the Rotel. I could pull it off the Rotel head shell and attach it to the Thorens in place of the Stanton and just get a stylus for it. Or I could buy a whole new cartridge and stylus.
