I ran across four speakers today. The muntz fcs-164. These each have a foster fe-163 driver, and a foster tweeter in them. It appears they are xover at 8k,
I did some googling and found a website that had a little info. It was all I could find. I have posted below what I could find.
Anyone know about these drivers, any opinions on them, any actual specs available on them?
Thanks
Mark
Rating of a mode
System 160mm full-range speaker unit
Play frequency band fo-16,000Hz
The minimum resonance frequency (fo) 40Hz - 60Hz
Impedance 8ohm, 16ohm, 200ohm
Output sound pressure level 98dB
The maximum input 10W (nominal value 5W)
Cavity magnetic flux density 10,000gauss
The total magnetic flux 49,500maxwell
Equivalent oscillating radius 6.5cm
Vibration-system equivalent mass 6g
Qo 0.3
Aperture 160mm
Baffle bore diameter 140phimmm
Dimensions Width 166x depth of 137.5mm
Weight 1.260kg
