Brandon J.
Member
Anybody know anything about a SAE Mark 1B?
Today during my lunch break I went and got my hair cut and then stopped in a little second hand shop that has some used electronics. Now normally they just have BPC, but today they had a SAE Mark 1b Preamplifier. I asked the guy how much and he said $49, then I asked him if I could return it if it didn't work and he said yes.
I took a chance figuring it must be worth atleast $49 even if it was broken. Well, unfortunately it is - or atleast it does not seem to power up. I checked the fuse with my multi-meter, and it's good, what should I check next?
I popped open the cover, and found where a a tech had apparently written when it was serviced - 1988. I thought the power switch maybe suspect, but I'm not sure which points to probe. I't looks like two of the main filter caps may have been replaced at one point, and whoever did it used some "white gluey stuff" to keep them in place. It also looks like the power indicator lamp may have been replace at on point - with a shoddy repair that didn't hold up.
Is it worth going through pains to bring it alive again - the exterior and most of the interior look great - it does have a heck of a lot of oxidation on the RCA plugs though. I know (or atleast think) that SAE was a very good if not well know brand, and that these were expensive new.
Any ideas:tears: ?
Any ideas:tears: ?
