Free Seeburg (Freeburg) - Cincy
Free Seeburg Hideaway Juke Box- Model HLPC1
I'm not sure if it works or not, and will need to be hooked up to speakers.
It is very heavy but is on wheels. You will need to haul and load by yourself.
I will only be home at 11:30 tomorrow, must pick up then.
So, if you show up at 11:29 ................ or at 11:31 you're outta' luck??
I had the home 33 1/3 rpm version with rotary dial that used a Pickering cartridge. Only guy on the block with one. Getting it to run wa a bit of a nightmare as the guys who pulled it were not gentle. Seeburg at the time was very helpful and knew a guy who was a Seeburg maintainer. Surprisingly, the sound was not as bad as I thought as I thought it would be; actually quite good.
I was going to keep it but, finally gave it up. It ended up in a local am station that loaded it up and payed all othg music using it.
