It's wrong above 10 kHz. Need to be on-axis with the tweeter.
Get the mic stand and mount adapter to work under standard conditions.
The room interference node has now moved to 300 Hz.... :yes:
Is there something going on at harmonics of about 95Hz? It looks like there are dips at about 95, 190, and 300 (+/-)?
Does the RS "calibration" file take the C-weighting into account? IIRC, C is down 3dB at 31Hz on the low end and 8k on the top and down 6dB at 12kHz. That looks to be about how far it's off from "flat".
Ray
Most likely a hard surface that's causing a 1st reflection to cancel the initial wave. At 100Hz you're looking at ~10' wavelength so a pathlength difference of ~5' will be the culprit. If the measurement is made at (or near) 1m then find something that's a pathlength of 8' from the speaker to the mic. Is it 4' away from a wall? The floor? Throw together a quick and cheap sound deadening panel and put it there and see if it goes away. Chances are at that frequency it won't totally go away but you can probably knock it down some.
Note: that's why we measure the low end in the near field (~1/4") and also where MLS and gating come into play.
Ray
When you're measuring, where is the mic? And are you playing one speaker or both?
My listening space (the basement) is probably far from ideal. It is 18 feet wide and 33 feet long. On the end where the speakers sit, there is an additional enrty way area (4.5 ft x 10 ft) that adds 4.5 feet to the width of the 18 ft wall. The door to the garage is there and stairs going up to the main floor.
The basement has a 7.5' drop acoustic tile ceiling and has heavy wall-to-wall carpet, except in the 4.5'x10' entry way, which is ceramic tile.
There are two support posts in basement that run from the floor to ceiling, they have been enclosed with wood and measure 8"x12" square on the cross section. The one on the listening area end is 9.5 feet from the 18' wall and about 3 feet diagonally from the listening position.
Is the column in the picture the likely culprit?
Plan to get a mic stand for the SPL meter this week per Zilch's recommendation.
Your mic must be at the precise acoustic center between the speakers to measure the two of them concurrently; I mean within 1/16". One speaker at a time, moved out from the wall 1M, and mic 1M in front of it, in line with the tweeter, is the preferred measurement methodology.Playing both speakers then doing the measurements.
Not tuning the room here, rather, measuring frequency response.Go to the web and put in Real RTA. If you have a laptop use this program about $99 dollars. You would need a small USB mixer and mic. Behringer makes a mic for $50 that is pretty flat or if you want a A+ mic try a Earthworks the best, you would have to dig deep for the Earthworks. That is the best way to tune the room. Add a 1/3 octave Eq and cut the bad frequencys
Pretty slick once you get it set up, eh? :thmbsp:
I haven't even gotten into the other tabs yet for RT60, waterfall, spectral decay, etc....
Are you running with the HF Comp engaged on the crossover?
Also, is the test tone continuous noise or burst(s)?
Not a sweep of sinusoidal tones, right?
No problem with that, actually; just wanted to know what methodology was employed.... :yes:The tone is a sweep from 30 to 20,000 Hz, don't see that there is an option to do anything else in the software.
