1984ericfx
Ok so I'm getting ready to build some speakers stands and an under the tv media stand
Right now the current plan is this
Audio equipment Wood Flooring Floor Electronic device
I would be using 1" black gas pipe
The other option that I've considered is making the media shelf. The full width of the television and
Making an open area under the stands that would allow me to place the subweer, either in the left corner or on the right side under the Paradigm Titan v6 bookshelf speakers.
A friend of mine had suggested making an open space under the media stand which allow me to have the full length of the television uptop, but still fit the subwoofer, underneath
the problem with this is, it would have to be about 26 inches tall In order for that to work... currently, the t v is setting at about four feet in the air, and I would like to lower it by at least 18 inches and I still need to be able to clear the Paradigm cc-290 v5 ceneter channel
obviously the picture I'm showing you is an AI generated picture but it seems to have got the dimensions fairly close.
