I had aVTA120 built with some customization. I eliminated the ugly quad can cap, and designed my own unique power supply. I used 2 Emission lab 274b mesh plates , wired in parallel. I used an 8.7. UF first cap, and 20uF for 2nd cap. I added 2 dual section caps 16uf+ 32uf. And a 50uf +50uf dual section cap, kept the resistors that are supplied with the VTA 120. Finally, I ran 2 chokes in parallel ( the stock c24 chokes). A matched quad of KT88 Mullard reissues. Sylvania (5953 gold brand in the 2 phase inverters,)and aGenelex 12au7 input. The parallel 274b’s can supply about 180mA each( over 310 macombined) my B+ is close to 500 vDC. Parallelrectifiers cuts impedance by 50%.The stock single GZ34 is almost at 100% of its maximum and is inadequate!( even in st70 clone it is over matched with EL34 or 6CA7 power tubes.
The 274b can easily handle over 300 mA@ 500+ DC volts are easily handled as well. The tube lag is almost non-existent, as the parallel rectifiers have Much less impedance (50% less voltage drop!) You gain 30-40 volts in B+ and the response is quick like solid state rectifier ( butmaintains tube sound) . And the mesh plates are slow warming, so they protect the power tubes,Dont try PSVANE 274b’s; they are “instant on” Direct heated, and slam the power tubes with 500voltz while the kt88 Are still cold. I tried the PS Vanes; they work, but are not comparable to the EMLs. The EML mesh plates are easy on power tubes. And the EMLz use 2 amps heater current; the PSVanThey also are dead quiet, no static, sparks, no noise. And no red plates. I had a russian gz34 almost light on fire! It red plated and burned to a crisp! It cant handle the stock setup. It even failed with el34 powder tubes. The sound of the amp is awesome! I get about 65 watts per channel.
The elimination of the quad can cap was no problem. EML told me I could use 8uf first cap wifh parallel rectifiers. The 274b are much less stressed than GZ34. The EML mesh plate are costly, but the circuit is easy on the 274bs. I have run the same pair for almost 15 years, and they still test very strong. They are very well made, and will outperform any 5AR5 ir GZ34. They only need 2 amps each for heater. And they look great! No hum at All. And you can even run stronger outputs than kt88! Kt90 are possible! You can replace the two
