I have a pioneer PL-530 that I just went through and this thing is running like a Swiss clock. Fully broke it down and cleaned it up as well as replace the foam for arm return. I ground down the rivets on all three micro switches so that I could open them up and use a Jonard contact burnishing tool to clean them up, every contact down to 0.01 ohm or lower. I also applied a small drop of Deoxit D100l to the contact point and closed them up with the original rivets. Everything on this table is functioning perfectly except-
You hit the play button, the tone arm lifts from the rest and moves over, and lands on the record. After about one second of playback, you get a fairly loud pop through the speakers. That’s the only time it does it in play mode. The very moment you hit the stop switch you get the exact same loud pop, then the tone arm lifts and move moves over to the rest and lands. I’m guessing it has to be some sort of switch or something, maybe one of the spark arrestors or the suppressors is not functioning correct correctly? Curious if anyone has any knowledge on this, the record player is still usable, but having those loud pops is pretty annoying. I was playing a record on a small Onkyo integrated amplifier and every time it popped it would kick the protection, then you’d get the Audio back after protection relay turn back on.
I’d really appreciate any assistance with this annoying issue.
Dan
Dan
