Fun New 'Toy' - dbx DriveRack PA2
David_NC
I'll be working on the biamp conversion of my ADS M12's over the weekend. I also use a subwoofer with this setup, so I need a 3-way crossover for this. One pair of outputs will run the mids and tweeters from a Dynaco ST-70, another pair of outputs will go to a Parasound HCA-1000A which will power the twin woofers in each speaker, and an SVS subwoofer will get a mono signal from the remaining pair of outputs. I currently have an older dbx 223XL 2-way crossover to enable me to use the subwoofer with these speakers. I came across a NIB DriveRack PA2 for a good price and found a Dayton calibrated mic on sale that will work fine with this unit.
I finally got it connected last night, though I'm only using it as a two-way crossover at the moment. Connections are straightforward, as expected. Configuring the device... I'm just glad I got the PA2 model instead of the older PA. The later model has an Ethernet port that allows for PC, Mac, iOS, and Android app configuration. This is is a good thing, as I can't imagine setting this unit up from the front panel with the unit positioned where it is in my setup! I used an iPad for setup.
The main screen is pretty straightforward:
Setting the crossover was easy, though it took some trial and error to find what sounds best. You simply touch one of the 'boxes' and change the settings from the screen that pops up. You simply touch an icon to select the outputs you want to set and slide back and forth. There's a dropdown for multiple types of crossovers and slopes.
The parametric EQ is one of my favorite features so far. I have a weird bass 'hump' in my room due to the room layout and where my speakers are positioned, and there's no real way to change the locations. I touched the frequency line on my iPad, pulled down slightly to cut the level, and moved my finger right and left slowly until the resonance was reduced. I then moved the line up and down to maximize the reduction while minimizing the impact on the sound. This made a huge improvement in clarity.
Once I got this far, I played with it a bit more and then listened for a couple hours. It has some fun features, though who knows how much they'll be used. There are speaker delays, a graphic EQ, and Auto EQ, among others. The subharmonic synthesizer is pretty cool. I used it on some poor recordings with reduced bass, and it seemed to help. I tried it on a modern track with lots of bass, and it did indeed synthesize some deep bass! I don't know how often I'll use this, but it was certainly more effective than boosting the bass or using loudness.
So far, I detected no hiss, added noise, or other unpleasantness from this unit, though I've read reports that some have had noise issues. It's a definite improvement over the old crossover I was using, and the ability to configure with an app that's really pretty intuitive is a huge plus. It'll be interesting to analyze the sound after I have it configured to where I think it sounds good and compare to its auto eq'ed settings.
Hey there! I hope you're doing well.
I've been thinking about getting one of these for years to help with sub integration and room correction. I have an abundance of time right now so I may have one delivered along with the mic and a long mic cable. I think one of these would keep me busy / entertained for a while, and they are actually much cheaper than I remember them being.
Are you still happy with it? Have you had any issues worth noting?
Thanks!
-Matt
Mine and here too along with a Dayton measurement microphone. So excited.
I keep hearing about this unit. From what I've read, I think it may be sweeter than the mini-DSP. I may need to add one to my stable. Just for the fun of it. :idea:
Thanks!
-Matt
I'm still happy with it and have had no real issues. The one issue I had was that the unit locked up once when I was saving a configuration. This required me to power cycle it. For some reason, it never happened again, and when it did, it was still filtering and equalizing properly; I just couldn't make changes while locked up.
I'll be curious as to your thoughts on it, once it's all set up.
The specs for the mini-DSP models I was considering were much worse than the dbx, and I read multiple comments about them affecting the sound negatively. I haven't read any such criticisms about the DriveRack. The upper model mini-DSP units were much better reviewed, but the prices of those were multiples of what my entire DriveRack, mic, and cables cost, and I'd still not have all the flexibility.
Thanks for the feedback! I've ordered a PA2, RTA-M (the dbx mic), and a 25' XLR cable and hope to have it by the end of the week. I'm looking forward to setting it up and tweaking things.
That reminds me - I need to get an RCA to XLR adapter or cable for my sub. I'll do that tonight.
-Matt
I got one about two years ago, finally inserted in my garage system, 4 Tapped ported horns for bass, 4 Mackie C200's,
Two Inuke DSP-3000 driving the Subs, two Crown 1502 driving the Mackies.
A great unit really allows on the fly tweaking. Much cleaner sound with it vs without.
I also inserted my Yamaha DSP-1 processor, after the two channel mixer which adds some effects to the mains. really interesting adding the effect in moderation to an open air Environment!
Just got my PA2 and RTA-M hooked up today and *wow* are there a lot of things to play with and explore on this. This will definitely keep me busy for a while.
So far I've experimented with a stereo full range configuration and a stereo full range plus mono subwoofer configuration. Most of my time today was spent in the crossover and auto-EQ blocks.
After reading the manual and educating myself on gain staging, I have reduced the front panel gains on my MC7300 significantly. Previously I ran them wide open on the 2.5V sensitivity setting and rarely turned the volume past 40% on my C52. Now the controls are at the 10 o'clock position and I'm pushing the volume up to about 60% to get the same levels. Still have lots to learn here.
-Matt
Now it's fully integrated in my system between my emotiva pre and liberty power amp. It is fantastic. Right now it is only functioning as a crossover but when my new speakers arrive I will use the measurement and peq features. I love it. Did not change the sound of my speakers. All pros no cons.
