Fuses on Apt Holman preamp
steelglam
AK Subscriber
Anyone know where the fuses are on an Apt Holman preamp? I can't seem to locate them inside the unit, or on the schematic for that matter. My unit no longer turns on, and I think I may have blown one of the fuses.
Thanks in advance for any insight!
It could have a fusible link or internal fuse inside the power transformer. Can you post the schematic or at least the power supply section?
It has a fuse! It shows a 1/8 amp slo-blo pigtail fuse just before the power transformer. Should be located near the power transformer or the main line power input somewhere. It shows it's on the schematic.
OK, wow. I'll dive back in tomorrow or the next day and see if I can find it in one of those locations. Thanks much!
Find the green and black wires from the transformer. It's tied to them on one end, and the three switched outlets on the other. Looks mighty tight in that transformer shielding box...
I replaced the fuse, and it works now. It was a really tight spot, particularly at the bottom connection, so I had to do some improvising by leaving some of the old lead in place at the bottom and soldering the new lead onto the old one. But it worked!
The "tone defeat" is still giving me problems (cuts out one channel when disengaged), but at least the unit is working otherwise!
Thanks for all of the help!!
