mattsd
I recently got a TU-9500 in for repair that had a problem with constantly flickering lamps, turns out the power switch was the cause, it would measure between 1K ohms to 15K ohms in the closed position. The power switch is an interesting setup, the toggle actuates a basic plunger style switch rather than using the toggle switch directly. The plunger switch is also sealed so it cannot be cleaned. After doing some research, I found one that looked identical in the datasheets to the old one so I pulled the trigger and got it today. I'm happy to report it is a perfect drop-in replacement for the old switch! Part number from Mouser is 653-V102C24 and Digikey is Z5104-ND.
Old vs new:
New switch in place, looks identical except the terminals are slightly longer.
Old vs new:
