Rad Grozev
Member
Hi all,
Bought the receiver yesterday. Auditioned it at the seller but should have been more thorough. When back home, turned on for a first time, a few potential issues were evident and I hope to get some help here.
After switching ON, I heard the relay click multiple times like a popcorn, then the green light went solid and it was working fine. After playing around with it, testing inputs, finding more issues, I turned it off, waited for a minute, then switched it back on. This time no relay click, straight to solid green light with boomy hiss through the speakers. Can't be normal, what do you reckon guys?
I wander as well, does the unit suppose to work with the build in antenna only or external must be connected to play any station at all? Because I don't have external and tried to listen to some radio but it doesn't pick up anything at all. Not sure if this is a fault or normal.
About the other issues, I believe cleaning with D5 will help. The Selector knob doesn't pick up signal from Phono 1 and 2 when turned, have to wiggle it then it's ok. Right channel at first was mostly off, then switching between sources, it started coming on off, then played fine.
Thank you everyone
Rad
Thank you everyone
Rad
