gregmcm
Have acquired a recent G-7500 project that is now operational. This unit was most likely sitting somewhere for quite some time based on the dirt and dust that was in evidence once I opened it up. Cleaned everything, deoxit the pots and the unit worked fine with the exception of the phono stage which was repaired and now both phono 1 and 2 working. (bad capacitor and resistors)
After running the unit for some hours here is the problem:
- turning the volume to say ~5 on the dial and the speaker relay kicks in and cuts sound output (same for all inputs whether phone, AM/FM or Aux)
- turning the unit off, wait 2-3 minutes - turn unit on and now have output
- listening carefully to the left channel at a reasonable volume and I notice a slight bass distortion. Also might be an even slighter bass distortion on the right channel.
Background:
- I haven't adjusted the Driver Circuit Board for DC Offset and Bias Current on this unit
- I have the schematics and a DMM
- I have adjusted Bias Current on a Sansui G-3500 that I have but this unit doesn't have DC Offset adjustment so I have some knowledge in this area.
- I have mini grabbers and know enough to make sure I'm very careful when making these adjustments.
Questions:
- Does it matter which adjustment I undertake first - DC or Bias
- Does it make sense that either of these adjustments would cause the conditions noted above?
- Anything I should be aware of before undertaking these adjustments.
- am I missing anything?
Background:
Questions:
