gregmcm
Picked up a G-7500 project with mostly cosmetic issue. Cleaned it up, deoxit the switches and turned it on. Lights up, no smoke and nothing unusual
. Checked AM, FM, Aux and all working fine. Didn't immediately try the phono inputs on the assumption they would be fine but now that I've plugged in a turntable I discover no sound on either Phono 1 or 2. Bad assumption. Checked turntable and it is in working order. Also did another deoxit of the selector switches as they are always problematic on these old units but still nothing out of the phono inputs.
My thinking is that the F-2852 Equalizer Circuit Board is where the problem likely resides. A visual inspection and there are no obvious signs of component failure. At this point I'm thinking a transistor problem. There are 8 transistors and 4 FETS on the board.
Questions:
- should I check the transistors or the FETS first?
- can these be checked in circuit?
- is going down the road of checking the transistors/Fets the right track or is there some other test that would be better as a starting point?
I have the service manual, schematic and a digital multi meter. Thanks
Questions:
