MAXZ28
Addicted Member
I've gotten sort of burnt out on my speaker shenanigans as of late so I decided to work on a couple of DOA Big G receivers I have laying around.
DOA #1 G-9000.
Symptoms - No power, no sound, nada. Does nothing when you flip the power switch.
Tested all fuses. Fuses all good.
Isolated to 3.9 ohm soft start resistor...replaced. Powers up on dim bulb - stays in protection.
Pull the F-2806 pre-driver boards [ will inspect them later ] and all output transistors from circuit. Powers up on dim bulb - comes out of protection.
Test output transistors -all good except one Sanken 2SA909 and one Sanken 2SC1586 on the right channel. I don't know if I'll be able to find originals but B&D seems to have some 2SC1586's in stock, but no 2SA909's only a sub- MJ15023G's. Same story from electronix.com - no 2SA909's.
Now before I get overzealous and order these, does anyone have recommendations where I should purchase these outputs or their suitable substitutes? :scratch2:
Thanks in advance! :thmbsp:
DOA #1 G-9000.
