G-901
I recapped most of the unit and went to test it with a dim numb tester and everything is ok unless I plug in from the power protection board the main oval capacitors, then the bulb shines bright indicating a short.
I checked the output transistors and they are all fine. Driver boards are pulled out as well. What could be causing this short?
