sansuilove
Hello all
My basement G2000 is making a big distortion in the left channel.
Measured voltage at it and it's the same as right channel (which is OK)
I swapped the output transistors and driver transistors between the 2 channels but still no change - left still distorted .
Preamp is fine so I know it's a power amp issue.
Would love to hear any tip or idea what to check next . (I have an oscilloscope and also signal generator).
Thank you
Thank you
