Sgt Shultz
Addicted Member
I’ve been looking through the site searching for “G22000 protection issue“ and it does seem to be a common problem. The AR9s are biampable maybe I’ll try that just to see If it makes a difference. I may just have to come to terms with the fact that it’s only 8 ohm speakers going forward. It does really make me wonder why the G9000 seems unfazed though. I can’t imagine the protection circuits are that different. That soundcraftsmen amp seems like a beast! Im sure it sounds great with those AR58s. I’ll play with it all this week and let you guys know what I find. My main problem to troubleshooting is moving these things around. My main speakers / system are in the house with the ARs in the garage until I get the pairing right. So every time I want to test an amp I need to lug them out to the garage!!
Here's the thing, even if an amp drives them it may not like it and later issues rear their ugly head as I mentioned with the Belles I amps with the power switch. The Belles is no slouch, only 185W into 4ohms but enough current to pull a freight train.
Pics of the Belles
I really thought the Belles wouldn't have any issues, never got hot, but the power switch stopped working. It did malfunction in the closed position so the amp still worked but no way other than unplugging it to shut it off.
Thought it was just a bad switch so installed another of my Belles amps while the first was being repaired. The switch in the second failed, hmmm, something's amiss here. So now one amp the switch keeps failing even with other speakers so there's other damage from the AR's.
So I went shopping and found the Soundcraftsmen and no issues since.
I have the Belles driving fairly power hungry Infinitys without issue so figured the AR's wouldn't be an issue.
Mentioning this only as food for thought about running those AR9's with other amps not 2ohm stable you care about
