G22000 G33000
Snowbum
I am restoring a G22000 amplifier with G33000 tuner. I've done extensive repairs on these types before, and the present units are done and ready to be connected to each other. The previous owner of the G33000 tuner had snipped off the 12 pin plug and cable, and threw it away!! I thought that I would simply make up a cable to connect the two units, using identical colors in both units where they connect to the PC. WRONG!
In analyzing the G33000 PC board pin numbers, and stub of wires still connected from the old cable, I find that they do NOT correspond to the same pin numbers/colors on the Amplifer's 12 pin socket....and then, worst of all, I found NUMEROUS errors on Sansui's OWN schematic diagrams regarding these.
I need to connect with someone with one of these tuners, to make some simple checks on pin numbers, colors, and circuit ID numbers for me; OR, simply get a cable with plug from someone that has removed or snipped it from the tuner. Would save me a LOT of hours.
Any help appreciated.
Note: I have a large number of Sansui factory manuals, parts, etc...as well as other audio manufacturer's. I intend to retire from 35 years of audio repairs in late 2008, and will offer all my stuff on AudioKarma's Classifieds.
Please contact me about the G22000/G33000 directly at:
snowbum@JPS.net
Thanks!!!
Robert
LBPete or EchoWars would be THE guys to connect with......:yes:
Snowbum, since nobody said it earlier, Welcome to AudioKarma. There are a number of very talented techs here that love to talk shop. We would welcome your experience.
Both EW and myself have fought the discrepancies in the manual regarding the umbilical connections. That information was posted on this board at one time. The illustration may have been lost in one of the server crashes. I'll see if I can dig it up.
The threaded collar on the socket on the front of the amp unit tends to break off if it is over tightened or stressed. I needed to replace it on one of mine and was unable to find the one that Sansui used. The company that made the original connector it is still around but they no longer offer that particular connector. It was a real headache to mount a different connector on the the amp unit. If I were to do it again, I would run a pigtail out of the amp unit and use an ordinary in line connector.
- Pete
I found it. Here is the correct pin out from the umbilical connector to the F2902 left power supply board in the Amp section. The numbers on the left represent the numbers on the back (harness side) of the connector. In the middle is the wire color. The numbers on the right represent the connection points on the board.
1 - Brown - 11
2 - Red - Ground lug, (board corner screw)
3 - Orange - 18
4 - Yellow - 26
5 - Green - 24
6 - Blue - 22
7 - Violet - 20
8 - Gray - 30
9 - White - 16
10 - Black - 12
11 - Lt. Blue - 14
12 - Pink - 28
- Pete
Yes, those colors and numbers are pretty much as I found the AMPLIFIER, except for 10-black, going to 13. However, my query had to do with the color of wires not corresponding in the 22000 amplifier versus 33000 tuner. The SAME colors in the amplifier and pin numbers DO NOT correspond to what is in the tuner, and, if connected per the diagrams, things would likely smoke. I need to know, specifically, what pin numbers of the AMPLIFIER really go to what PC board numbers in the TUNER-Preamp chassis.
It would be helpful, if anyone has the information, or can test and find it out for me, to post to me DIRECTLY, as well as to this forum....I had the darndest time finding this thread after initiating it. I am at:
snowbum@JPS.net
thx
Rob
The missing pic...
In reply to Echo Wars....is that sketch from one of the Sansui schematics, or from an actual look-see of the units?
thanks,
Robert
That's a diagram he made to correct the Sansui schematics. You can take it to the bank.
- Pete
Thanks for that sketch. I found time yesterday to check it against the homemade cable in the pre-tuner unit, and it DOES agree. Next, to find time to check the colors versus what is what at the amplifier end INSIDE...not just pin numbers. OH...and I surely knew that the sketch was not from Sansui schematics....I wondered only about the notations on it.
I'll check back in as soon as I can dig deeper. This particular Sansui 'pair' belongs to a close friend, and all this work I've been doing, to repair the amp, and make the cable, etc., is being done as a favor to him. I'd surely hate to have it in the shop and have to charge a customer for all this work.
Thanks, also, to the "welcome" to AudioKarma. I've been in the audio repair business most of my life.....still do some, mostly musician's electronics these days...but sometimes esoteric audio. Getting old, cranky, cantankerous, curmudgeonly, and so on...:-)....comes with being 70 I guess...
I think I've also solved my problems about getting to and on this Forum. To love computers is to hate computers. I hope to contribute what I can...quite a few forums to look at though...
Robert
snowbum@JPS.net
Robert
snowbum@JPS.net
Same here. Old, cranky, cantankerous, curmudgeonly and 67. In an early life I was an electronics tech and worked several very interesting jobs incl. product development. Then I joined IBM and they made a big mistake -- they introduced me to software (well, I guess Autocoder was considered software way back in the early 60's :D) and I never returned to electronics until the last 7 or 8 years. I spent those nearly 40 intervening years in Assembler, COBOL, Fortran, PL/1, System/2000, Basic, system analysis, DBA stuff etc. etc. etc.
Paul
Well, just an update.....due to an emergency job for a recording studio, have not gotten back to the Sansui mess. Expect to in a few more days. Next up is to check the amp section for the colors/pin numbers, then the actual circuit functions. Meanwhile, I did find some time to put some of my Marantz service manuals on Ebay. Will be eventually getting to the Sansui manuals too. Want to retire to at least 90% by the end of 08.
Thanks for the help, all....will be back with a note on this monster asap.
Sorry...just saw this.
I replaced the male and female end on a buddy's G-22000, and had to know what was what. The SM was useless. I traced it out myself.
IIRC, damn near half of those wires are ground.
