G5700 Recap - Main Filter Cap Values
ZeroG
Often on AK (esp. with Marantz pieces) it has been recommended to upsize the main filter caps for better bottom end. Sure worked well with my 1060.
Just acquired a great looking G5700, and would like to do the same thing. The main filter caps are 8200uF 63 V.
What's the max size I should use on that? Or should I stick with the stock values?
Thanks!
First try to find replacements of the same size and termination, then I would go with the best quality cap between 8,200uF up to 15,000uF. You can also go up in voltage, 80V might get you some more options.
Thanks. Does the power switch then need an upgrade too?
