Garrard 401 dimensions
Subchannel
Anyone here have the height of the Garrard 401? I´m making a plinth that´s going to be flush with the 401 on top, so I need the height (preferable in mm) of
the body/ top plate of the player. Not with screws/ motor/ platter etc. It´s a few weeks until I have the turntable and want to start building.
thank you in advance,
Subchannel,
mine measures 13 mm for the main part of the base and 15 mm to the top of the control panel trim. The edge of the base tilts slightly inward so if you make a 90 degree cut, there will be a slight gap at the top. I didn’t try to measure that angle. Maybe someone else knows and might confirm my numbers.
They’re great machines. Good luck with your project.
Doug
