Garrard 401 restoration help
Alfmonster
Hi AK —
I’m very exited as I’ve recently picked up a Garrard 401. I have restored a Thorens TD150 mk i but am realizing this is a whole other beast.
I’m not sure why but I can’t seem to find a webpage or video that explains a how to restore a 401 — Can someone kindly point me to some help as to how to strip the motor and restore this?
It did not come with a power cord - and it’s rated for the Uk - so did pick up the 50hz pulley and an idler wheel from audiosilente.
Any help would be as always so greatly appreciated.
thanks so much in advance!!
Hi AK —
Hi,
There's not too much difference between restoring this one and other idler wheel turntables, it's all down to similar stuff:
- Idler wheel should be pliable and smooth and the surface should be perfect.
- Motor suspension should be compliant
- Motor should be overhauled and adjusted to diminish vibrations (this is doable only on motors that are adjustable, dunno about the 401)
- Platter rim or surface where the idler couples should be clean and smooth, the same about the motor spindle
- Clean and lubricate the main bearing
- Put turntable in a massive plinth.
Aditionally the 401 has an eddy current brake, that's the only difference with a big majority of idlers i can think of.
