Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Tough to say, never had the Garrard before but I have owned the black version of the Akai AP-206C. The Akai was a very nice table. I would go with the Akai just because I prefer having my 33/45 pitch control separately and the layout of the Akai. But, I am sure either one of them are very good. I am just more familiar with the Akai. Between the two I would go for the one with the better cartridge and/or price.
The Akai is technically a better deck. Those Garrard DD decks had a lot of issues when new, the end of the line for the real Garrard until Loricraft bought the name.
i also have the akai ap 206c...its a great little turntable..nice ergonomics.
keep the akai pc100 cartridge..its as good as any of the current budget cartridges available..and its tri-pole induced magnet design probably beats the majority of them on channel separation figures alone..(with the caveat mentioned below)
In addition to the overhang method above..if you stick with the akai cartridge i also would suggest you try aligning the cartridge to the baerwald null points for a tonearm mounting distance of 205 mm...it really does make a difference when it is spot on as the pc-100's cantilever design is a bit more critical of accurate set up than most other budget cartridges i've tinkered with..
Ah, yes. I had forgoten about that. Funny, I was just looking for the overhang the other day and was stumped when I found 15mm, but it's 15mm from the spindle and there is a groove in the mat to use for a guide. How ingenius of the engineers at Akai. I was thinking that the overall headshell overhang was 49mm, same as my Pioneer. Well now I guess that I can check it sometime.
