Stockman
I recently picked up this turntable. It is in xlnt shape except the motor rattles horribly. Does anyone have experience with this motor (picture attached)? It seems a bit different than the other 100 motors on the outside, but I suspect it is the same inside. Advice and/or an exploded diagram would be great. On disassembly (see pics) there is a big thick metal washer floating loose above a non-metal black piece that is glued to the armature. I suspect this loose metal washer is the rattling piece. If so, should it be glued to the armature and will where I glue it affect the balance? (I note drilled balance holes on the end of the armature stack.) Also, the bottom cover cap has no real bearing in it, but looks like it should have a ball bearing or something? The end play of the motor when assembled seems acceptable. Thanks.
