Garrard Zero owners support group
bobforapples
Angular banjos sound good
Hi, my name is Bob, and I have a problem.
These things are a PITA. :yes:
Long story short, I acquired 4 broke Garrard Zeros that have been sitting under a few inches of filth for the last 10 years.
It take me about 4 hours to totally strip the things down, clean, lubricate, and reassemble.
So far so good, most of the problems I've found are just from the old grease turning into glue, but man, these things are touchy.
Has anybody else thrown one across the room in frustration? (not that I've done that...... yet)
Anyways, here's some pics:
I remember those so well. You did such a great job on yours; well done. I don't know how you ever got it back together.
I always thought that the articulated arm probably introduced more problems than it solved, and I never could quite understand why its design was skewed so far in that direction, but after seeing 'underneath the hood' now I get it. The designer was a lever-and-linkage genius; carburetors were child's play to him. However, I always figured they don't call them "tone-" arms for nothing; guess he did get that horizontal tracking angle right, though...and now that I think about it, with all that other stuff under it, why not?
That said...beautiful table! I would be proud to own it, and more so had I done the restoration myself. Now, think you could get my cuckoo clock goin'?
I just finished restoring an SL-95B, which as you know is nearly the same as the Zero 100, but without the fancy tonearm. I had to send the idler wheel to Terry's Rubber Rollers. No matter how thoroughly I sanded the idler and treated it with rubber rejuvenator, it would continue to stall during cycling -- and that was after the cam and cam followers were all cleaned and lubed.
Fred
dang! i can't believe you had the balls to COMPLETELY disassemble it. it looks great, great pix, congratulations...
Wow!
Congratulations on the beautiful Zero 100. I have a model 82 which is shares the same chasis. It has a fixed angle tonearm, a 10 1/2 inch platter, and includes 78 rpm. I got it in 1973 while in college and it has been in constant use since then.
I did a partial assembly of the changer mechanism to clean and relube about 5 years ago. So far, it has worked flawlessly since.
Although I could do a complete disassemble as you did on yours, I don't think I could have gotten all back together again. At least not in four hours!:D
Well Done!:music::yes:
http://www.audiokarma.org/forums/attachment.php?attachmentid=88524&d=1208917345
I have a Zero 92 that I have a hard time with - put it on ebay and yanked the ad because I couldn't go through with it. It looks funky cool, sounds good and I like it with 78 rpm. I wish it were the later belt version. Idler wheel gets tired every few months, and really not that quiet. De-gunking was a nightmare. My Dual and Bic get all the play time. I put some time into it, and am not ready to let go yet. Yes, I have thought about throwing it.
I had a Zero 100 in mid-70s only issue with it I had was the slight rumble that the idler drive made. I can recognize tapes I made with that TT because of the rumble in the background. Still have a few parts left over for it, the record stabilizer gadget, maybe the LP auto stacking spindle if I knew what it looks like have several, and a couple of the plugin cartridge mounts around here somewhere.
I know what you mean about the GREASE/GLUE I just restored a Garrard
Type A that had been sitting for years. Your O looks Really good how does it sound?:music:
The good news is your effort is worth it. Even with the flaws, the arm principle is 'sound'.
Beautiful clean up. But I worry about the fingerlift at the end of the arm -- its bent, and the force that bent it might have also damaged some of the bearings -- hope not.
Hi Nat,
That's bend is design. 70s chic, I guess.
Hey Bob,
Nice roll-up-sleeves work! I've attacked three of these in as many years. Still keep one in the stable. If you haven't found out already, the cartridge sled can get flakey in its fit. Sometimes this causes dropped contacts in the the signal or their grounds. Sometimes it gets to be so ill-fitting that the azimuth is off. Cleaning the contact bands and carefully making them a little "proud" with a toothpick almost always solves the contact problems. If the azimuth is off (the cant of the stylus out of perpendicular when looked at head on) a little Blu-Tac between the sled and the headshell can often offset that one.
- Mario
Hi Nat,
Hey Bob,
- Mario
I had a zero 100 and I DON'T recall that bend being there.
Just looked up pics....definitely no bend in the arm.
I don't recall the bend, but if you look carefully (which I didn't before) at the pictures of this one, its clearly intentional since the beam is milled away under it, and the curve itself looks like it was milled, not bent.
Who knew?
Mario,
Thanks for the heads up on the cartridge sled.
And,
The bend in the finger lift is not supposed to be there! I didn't even notice it!!!
The other 3 that I have are not bent like that.
Thanks for the good eyes!!!!!!!
Yes mine was not bent as I recall but otherwise a keeper. great job. Love that wood frame as I had the cheap plastic version.
