Speedbump71
Buried in speakers
Hello all,
I am currently planning a complete restoration on my Son of Ampzilla. I have decided to replace all of the capacitors and semiconductors, so the rectifier, diodes, transistors etc are being sourced.
I'm trying to decide on what the best currently available parts are to replace the following:
GAS101/GAS102: These are the original output transistors. Mine looks to have a mix of Sanken and original GAS parts. My plan is to replace the whole set with MJ15003G/MJ15004G from ON Semi.
2N6316/2N6318: ?? Maybe MJE15030/MJE15031 ??
GAS 107/108: Looks like they cross to MPSU06/MPSU56. Any modern equivalent for these that would work? Only source for originals seems to be Ebay at nutso prices.
GAS116/GAS117: Should just be a direct cross to MJE15028/MJE15029, but I am always interested in an upgrade or suggestions
MPS 8099/8599: These should be matched pairs. I see matched sets from China on Ebay, but I always worry about what I am getting when I order parts from overseas. If I replace these what is the best modern equivalent, and is there a good source for matched pairs?
MPS6001 Quad complimentary pair transistor IC: Should I even bother replacing these? Is there a better modern upgrade?
I will continue to do my own homework here, and I will update the thread with what I come up with, but appreciate anyone's suggestions on any or all of this. The amp powered up, and did not blow fuses, and there are no signs of any heat or failed components except for a couple of 1/4W resistors on the driver board that look to have some discoloration from heat.
