Rowrbazzle
I can't count the number of turntables I've seen where the tone arm lock mechanism is a little bit of cheap plastic which is invariably breaks off after a few years and/or some hard use. Sometimes it's possible to order a new tone arm rest and install it easily, but sometimes you have to remove the tone arm and replace an entire molded plastic assembly which includes the tone arm rest.
I'm just looking for ideas for a quick fix that is a little more elegant than wrapping a piece of tape or or a rubber band around the tone arm and tone arm rest stub when you have to move a TT. Any ideas?
