Just picked up these Genesis Physics 3 speakers. I'm told all drivers are original, and were recently re-foamed. I fired them up and they certainly have that nice laid back sound with nice soft highs from that inverted dome tweeter. The re-foam job looks pretty good, although not done as aesthetically nice as I think I would have. I did not hear any voice coil noises when playing music.
I wired them up to my Anthem Home Theater processor and ran a test tone through them to make sure the frequency response was adequate, and they were. But one of the 8" woofers during this test tone did make some noise (the tone sweeps from very deep base to the highs). Not sure if this is a big deal since no noise is heard playing music. The woofers during this test tone really move in and out a bunch! Could it be off center? Is it hard to remove newly applied foam if it is needed?
I will be removing the crossover this weekend to see how the caps look, and was thinking about some improvements functionally (new caps), but mostly aesthetically. Just wanted some thoughts or opinions if these improvements would be good or leaving them stock would be better. While good sound is of course important, as a former cabinet maker I'm a stickler for good aesthetics.
- I need to redo the grill cloth, should l go with the original brown color, typical black, or a beautiful beige cloth (like the old Advents).
- I don't like the Velco pieces to attach the grill, seems very cheesy. I was thinking about adding the plastic grill pegs.
- The mounting plate for the tweeter and midrange have the drivers offset to the left. Each speaker is offset the same. Not sure why they didn't make them mirror images of each other (one offset to left, other offset to right). So I was thinking about making new plates that are mirror images of each other for a symmetrical look.
- Thought about adding some internal braces to help deaden the large cabinet, which you can feel vibrate a bit when playing music with deep base.
- The speakers have real oak veneer, decent shape. Rear and front panel are of course unfinished (painted). Was thinking of applying new walnut veneer, and adding the veneer all around (including rear and front panel) to bring it up to furniture grade looks.
- The woofer and passive radiator have steel frames, and do not have the gasket around the outer edge to hide the area where the foam surrounds are glued (gives it an unfinished look). Has anyone added the gaskets to this area for a cleaner look ? Can probably even paint them green to pay tribute to the old green surrounds that are no longer available.
- The woofer and passive radiator are mounted on top of the front panel. Once again not a finished look. Has anyone recessed the frame to be flush with the front surface (like a few other smaller genesis models)?
Seems like a lot of stuff, but the only pricey step would be purchasing the walnut veneer.
