angelaudio
Initially this 9090db was getting no FM or AM reception, and after doing some research found that the F-2619 board supplies 12.5V to the tuner section which wasn’t being supplied because of poor solder connections on the heat sink and TR01. After resoldering the connections properly I made the adjustment to VR01 to show 12.5V. The reading was taken from the positive lead of C05 to chassis ground. Initially I got it spot on but I went back in today to check if my dial pointer lamp was being fed 6V (which it wasn’t) and checked to see if the F-2619 board was still supplying 12.5V, and it was reading very high at about 17V. What could be happening here? Adjusting VR01 wasn’t doing much to change the voltage this time around, could it be a bad VR01?
