G'day all, I must be feeling motivated today because I've been in the mood to get things done, and one of my assigned tasks was to check the cartridge overhang on my Kenwood turntable. In the past I had just used the supplied AT95E as reference and simply set up my other cartridges that get used on that turntable to the same measured distance, and since I've noted no IGD, I've presumed good overhang adjustment. Anyway I got out my Shure two point Baerwald protractor and magnifying helmet and checked it with my M97xE in place.
According to the protractor the inner null point was slightly 'out' so the overhang was readjusted as per my usual procedure at both null points (about a 1 mm shift forward). I then checked the tracking weight (with my M97xE) and it was close to correct (1.25 to 1.3 grams). I then played one side of a record.
I can't say that it really sounded much better, but two things were immediately noticeable. Firstly that record being slightly dirty, always produced a substantial collection of fluff around the stylus tip by the end of the side. Well I checked the stylus tip at the end of the side with my X10 magnifier and a perfectly clean tip was seen! Also on that record the cartridge always 'repeats' on a bad scratch and I was stunned to hear a 'click' but then it kept on playing normally! No doubt about it, getting the overhang right is a fiddly process but it is definitely worth it! :yes: Regards, Felix aka catman.
