GeoKost
Well-Known Member
GF TubeDAC-11 Hookup Question. Update.
I just received my TubeDAC-11. I will be running it into my Sansui AU999. Question is, use the TubeDAC-11 as a pre-amp and run it into my MAIN INPUT jacks by removing the pre jumper, or leave the jumper in and run it into my AUX jack.
Or, try it each way to see what sounds best? Is there an advantage or disadvantage of doing it either way?
Edit: I will be using the "Tube Out".
I also have a NOS Amperex 6DJ8 Bugle Boy, grey plate halo, O getter, Holland tube ordered, and also I have a NOS Zaerix 7DJ8 tube ordered. Both from E-Bay, so I hope they turn out good.
Your input or comments are welcome.
Thank you,
George.
Thank you,
George.
