Still the same question, how does that work?Plate choke for the driver
In order to develop a voltage at the grid of the output tube, the driver needs to work into a load. Typically that would be a resistor but in this case a choke provides a load but also allows voltage swing above the plate voltage and greater drive power for a given anode voltage.Still the same question, how does that work?
The current was calculated at idle, not dynamically, if that's what you're asking. It's posted on the schematic. As I understand it, current is essentially constant in a SE amp which is Class A by definition.@FlaCharlie Have you measured the output tube current flow? I'm really curious how tightly controlled it is, although luckily doesn't make a huge difference with SE designs, but it seems to me that proper bias for the output stage is contingent on all the component values (including the DCR of the choke) being relatively on target. Future builders shouldn't go about replicating this amp with different plate chokes unless they recalculate the relationship between the choke and the two voltage divider resistors in the output stage cathode circuit.
The 50uf caps are known as Ultrapath caps
It seems like the voltages on the schematic are actual measured voltages, and then the currents are calculated from that. So that can be taken as actual idle currents if we accept Ohm's law.What I'm asking is how closely the actual idle current matches the calculated idle current on the schematic. Was just curious.
That's correct. All voltages are measured, not based on a sim like Spice, which I have no idea how to use. I did run a PSUD sim but the results are suspect since the program can't be configured as a Cockeyed Bridge using a tube as a slow start device.It seems like the voltages on the schematic are actual measured voltages, and then the currents are calculated from that. So that can be taken as actual idle currents if we accept Ohm's law.
Yeah, that's basically what I did except that I added resistance between the rectifiers and the first cap but the results would be the same.you could probably fake PSUD to some extent by adding in some extra resistance to the secondary in the transformer impedance calc.
