I rehabilitated a TEAC 11040SL a few years ago that was given to me. The deck had usual mechanical issues and a few electronic issues as well. I replaced a couple transistor and fixed a playback issue.
A couple years later I was given two big tubs of commercially recorded 7 1/2 ips tapes from the son of an audiophile who presumably belonged to a tape club. I am so impressed with the sound quality, especially the dynamics.
Unfortunately, one of the heads on my TEAC A140SL puts out 70% of the amplitude of the other when I play back a test tape. It's visible on the left VU. I spent too much time blaming the electronics at first not being up on tape in general. Finally I put my o-scope on the wires from the heads comparing and verified indeed one head was putting out less amplitude. Head wear is visible on that head. I have to wonder if the tape tension has been excessive for the life of the deck.
I had anxiety though about removing/replacing/readjusting heads.
I've heard about dropouts being due to head wear but reduced amplitude?
Now I'm wondering if this might be a head adjustment issue rather. BTW I tried the "press the tape up against the head with a q-tip" test which did nothing
Thoughts?
Thoughts?
