Good smoker or no?
OK guys...my son is coming up from MD in a couple weeks and wants to have a smokeout and then have some meats to freeze and take back with him.
I havent done any long haul smokes yet so I need some advice on timing this out. I want to preferably get two smallish size butts vs one large one...a brisket..and possibly ribs will be involved. What would your process be in order to eat around say 6pm at the finish line? Stacking order matter?..like ribs on top..then brisket then butts?
From what I've gathered...pork runs about 2hrs@lb..brisket at 1hr@lb. Ribs are easy enough..I've done them enough at roughly 6hrs. Being new to me smoker I still dont know if I can trust it to let it go unattended for like an overnight smoke.
I'm going to do some meatloaf this weekend to dial in keeping the smoke box going at low temps. This lernin' is so much better than skool wuz!! :beerchug:
Lemme hear how you would go about it and your experience.
Remote meat thermometer.
Cook Brisket day or TWO before feast. Internal temp to 200/205 Degrees. No less no more. Salt the living **** out of it, before you cook. Whatever rubs you use test for salt but salt on Brisket is your friend. After 6 hours of cooking if the temp is not up there yet, (because you are cooking low & slow) Wrap it in Aluminum foil to keep it from drying out. If you want it to be tender. 200 degrees. keep and use all the juices in the foil. On feast day, oven warm it in a 300 degree oven for 40 minutes in the same foil. When you slice it to serve have the juices in the mix. Pork but is very similar but it can be dry so again after smoking for a period, 4-6 hours. Wrap it. Save the juice. When it pulls apart, about 180 degrees on the thermometer, pull it apart and add the juices. You can do this the day before as well. warm it with the brisket.
Ribs are best to me right off the smoker. Ribs are subjective but depending on what ribs we are talking about and how much meat is on them they are all the same in that they must cook low and slow to get what you want.
Internal smoking temp about 240 for 4 hours will yield edible ribs of any kind but not necessarily the best.
Here is where you do your thing. Do you sauce them? With a good rub you do not need sauce, but sauces are a preference and never hurts. 1/2 hour before serving slather em up on the heat let it caramelize for 20/30 minutes depending on doneness and time to eat.
When are ribs done? Well if you grab the rack with tongs and they fall apart they are over done but still good. I like to test them with the tongs. I sometimes cut full racks in half to cook. When I pick em up with the tongs I will see how they flex bending the end and watch the juices surface. perfect.
Sometimes temp can get out of control for whatever reason so time comes down. The Key is in all these meats is the fat renders when they are ready to come off the heat. Do not forget the salt on any of these meats.
Also depending on what woods you are smoking with 4/5 ounces of wood in the beginning is usually enough. Some people cannot take heavily smoked meet. Less is more.
The chimney is most excellent for searing 1 1/2” cubes of bluefin tuna. :)
Jealous
Not a lot of that fresh up here in MN but the idea of searing in that concentrated vortex of heat has me thinking.
Nope, too tall. Vortex bowl but you can make one from a stainless bowl.
https://www.amazon.com/XT-Medium-Ch...t=&hvlocphy=9018799&hvtargid=pla-796325716299
Did you see that Pork Belly going on that grill?? Very interesting concept. For the Webber cook who "thinks" he has everything.
Jealous
Weber Kettle Owners FB page is a great resource for all kinds of techniques and recipes. Everything from smoked queso to meatloaf, brisket, wings, etc.
Yep I have a good remote thermometer and totally understand what the salt does with meat. I'm not real big on sauces...I'd rather taste the meat mostly. I'm the guy that puts nothing on a good steak. The first ribs I did on this smoker I did a minimum salt and pepper rub with a couple other spices. I have the sauces on the side though and will baste them at least once at the end cook time
Meatloaf went on at 1pm today..so to be continued.......
Up yours Arby...I've got the meats!! :rflmao:
17lb brisket...a 7lb & 9lb butt...and 14lbs of eye of round. The eye of round is for my chili I have to make this Friday. I still need 5lbs of country store sausage yet for that too. I collapsed my fridge shelf last night. :(
I'm debating if I should freeze the brisket and butts or not. The packages have a use or freeze date of July 7th for the butts and July 11th for the brisket....cook day will probably be July 8th. I have my fridge around 34-36°...but that will vary a lot with chili cooking ingredients and in and outs of the process. What do you think..freeze or it will be OK?
