Goodmans Maxamp 30
i need a break from english engineering :D, the amp is back in the "to do" stack.
probably have some messed up wiring in the pre amp section.
on tape monitor it works perfectly good.
on tuner it works good on left ch and very low sound on righ, and if i press monitor i still hear the same low sound on right
on aux i get sound in both ch, only distorted (due to cd overloading the preamp) tried a cd with variable out and that works, but its pretty dark sound on both ch. like if the treble is turned down
and when ever i press tape monitor i get a serious dc pop on right ch.
other that that all is fine :)
i really cant find the motivation right now to go thru the wiring, it looks good to me, i havnt seen any broken or loose wires. and i dont even have a schematic to work with.
MODS you can move this thread to "British audio" :)
I am about to get this amp up on the bench again to start where i left off..
Status on the amp is as above...
I have been using it alot since it sounds very sweet. But the problems with it bother me alot.
Is there a maxamp guru somewhere?
