Boto
Curmudgeon In Training
Typically I only find CD's or records in the Goodwill. If they have anything around me it is junk. Imagine my surprise the other day when I found a pair of Baby Advent II's. $6 for the pair and sequentially numbered. Of course they need foam. Wood is real nice, no major scratches or stains. I checked the crossovers and they are real simple: just a cap, resistor and coil. They have a circuit board mounted to the spring clip housing. The only thing that looks a little difficult is that it is set up to take radial caps. I have some Solens that I can use, but like most replacements they are axial leads. I could clip off the one lead short, solder it to the other spot on the board and then solder it to the other lead on the cap. Not pretty, but it should work. Any other ideas?
