Just to verify your phasing, take a piece of speaker wire and hook it up to each speaker, whichever color or mark for your wire you consider positive. It is important for this test you hook each speaker up the same, although you are testing each one individually.
Then using a small battery, an AA or AAA works, touch the positive lead to battery plus, and negative lead to battery minus. The cone will move either IN or OUT! Then test the other the same way. BOTH should move the same way, either in or out, if they move differently, the phasing inside is incorrect!
I run 6's, 17's, 32's, Advent OLA's, and A25's, and I have a set of 60's on CL now. I didn't care much for the 60's, but I paired them with a Realistic STA-870, and have to say they sound very good, even better than I remember, but still not to my taste.
