Grado F3+ question
nolan
Banned
Hello,
I have a Garrard SL 95B,that needs a cartridge. I have a Grado F3+ I am thinking of using. The Garrard has settings for conical and Elliptical. I was wondering what stylus the Grado came with? Also,any issues with pairing the two ?
Thanks for any help.
Hello,
That's a 30 year old cartridge... pretty good though. The F3+ is conical, the F3e was elliptical. I sold/installe literally hundreds of them. It'll work well in that SL-95b too. Enjoy.
Hope this helps you out . I'd go with a Blue or a Red stylus .
I like mine .
Barney
Thanks guys,I appreciate the info. I knew it was old,but had no idea it was that old. I will give it a shot until I can buy a new cartridge.
Cartridge bodies don't wear out. Styli do. Drop in a replacement stylus and you should be good to go :)
I pulled a tan-body Grado FC+ off a thrift store turntable and tried to put a new Green1 stylus on it. Unfortunately I discovered that the old stylus assembly looks similar to the new ones, but they are not the same, and it is impossible to put a new stylus on an FC+. I essentially wasted $40 (that is, until the stylus on my ZC+ wears out in a few years!).
I don't know if this is the same case with an F3+, but it's worth confirming before buying a new stylus...
Interesting ,I had not thought of that. I better do some research before I buy a new stylus.
That's interesting beatcomer :scratch2: in my experience new Prestige stylus do fit in my old old tan bodies. Is it possible something's stuck down inside the FC+ body preventing the new stylus from fitting? Or hardened dampening compound (the black stuff) is blocking the way?
I too just checked on a tan bodied cart with a newer Silver stylus and it fit . Now I didn't play it on a TT but seemed to fit into the body just fine .
The tan cart was either a GF3+ or a MF3+ I have both and the silver is a newer black bodied cart .
Barney
