Grado G1+ Cartridge
majick47
Addicted Member
With a recent TT purchase along came a Grado G1+ cartridge mounted on the tonearm. It has a dark maroon and black body, overlapping GL in white letters on underside of body and G1+ Grace in silver lettering on the front of the body. Stylus is in good shape and it sounds fine. Couldn't find too much info re the cartridge other than someone claining the stylus is a shabita type, suspect it was mfg in the 1980s. Curious if it's a keeper or just an average Grado cartridge.
I picked up one of those and I believe it compares to the Grado Gold, their top of that line. If you like Grado, it's probably a keeper. I haven't played mine much, so I'm in pretty much the same boat.
Yes your G1+ does indeed have a Shibata stylus which makes it quite rare and indeed a keeper. Some like the G1+ cartridge a lot while others feel the bonded mounting makes it sound no better than a current Grado Gold which is actually not a bad thing at all.
Appreciate the replies/info re my Grado G1+ cartridge that it's current equivalent is the Grado Gold. I suspect it has very low hours, the stylus/canteliver is spotless and straight. From the replies it's a keeper MM cartridge.
The Grado G1+ had a nude diamond, original called "Grado Type" or "Special Grado Type", later "twin tip" but also "true ellipsoid"
The cantilever was not just straight but a tapered (conical) hardened aluminium cantilever.
There were 3 generations:
During the late F-Series:
Black body, black plate (replacement stylus) with yellow dots (the dots are important!) Black box
Grado F-1+.pdf
During the later G-Series:
Brown body, brown plate (yellow dots): Twin Tip
Last G-Series:
Brown body, brown plate (yellow dots): True Ellipsoid (Same as Grado Type or Twin Tip)
During the F-Series the Grado Type nude stylus of the F1+ and F2+ Grados were hyperelliptical but Grado never used this name but Grado type or Twin Tip
Later he called it True Ellipsoid (until now in 2026 with the Top of the Line modern Grados)
If somebody would find a bonded stylus on a G1+ or G2 (F1+ or F2 as well) then this would be a replacement from a cheaper version
and the colour removed.
If a TAN brown plate then from a GF3e+
If a black plate no dots, then from a F3E+ i.e. elliptical (those were 7x3 nude ellipticals !)
