CrSens
G
G-1+ stylus is a "twin tip" proprietary Grado top of the line stylus, and nothing like today's Grado styluses. I have experience with Namiki MR (Shure V15 VxMR) and I find old twin tips sonically superior in every way.It is broken just after the solid bit. The cantilever is slid over the solid rod and glued into place so the only way to retain the original stylus cantilever is to add an external tube splint which is ok to do but messy and will increase mass. You really can't do this properly without a retip and to do properly it will cost maybe 250 US not 100. These can be retipped with boron and nude Micro Ridge or similar which is way better than the old stylus and nit that expensive considering the upgrade.
Re using the old diamond, it is doable, but it is very difficult to remove glue from a diamond that is 0.1mm without pinging it. It can be done but it is cheaper time wise to use a new tip.
Chris
