Grado Green T4P compatibility
greenflash
Hi guys, I might be able to buy a Grado Green cartridge (seems to be a nice one right? I'm tempted to try the brand, does not have the stylus but I bet I can get one), and the seller indicated it's a T4P cartridge; I honestly can't tell the difference with other types? I'm using now for example a Shure M75/V15. Is it the same type?
How can I tell if it's compatible with my turntable/headshell? Thanks!
Does it come with an adapter ? :idea:
The following is a T4P cartridge and adapter.
You will need the adapter for a non T4P headshell.
images
Oooooh (eyes wiiide open!)
Thanks @Balifly, had no idea about that. Will ask the seller but the picture is below, and it seems to be missing the adapter you indicate in yours... So no go!
Except Grado doesn't make adapters for their p-mount cartridges, which are too tall to fit in nearly every p- mount adapter from other cartridge manufacturer. If you have a standard 1/2 inch arm, get a standard mount Grado, not a p-mount.
yes they do, its a square shaped piece that slides on from the back. the biggest issue using a P mount grado, with adapter, in a "standard" headshell is the size of the cart pins.
They used to make such a thing, but they don't now.
Finally scored a very nice and adequately priced V15 TYPE IV!!! Thanks to all of you guys, I avoided a mistake with the Grado..
Thanks!
FWIW, you can easily get a Grado P Mount into a half inch adapter with a plain old file. You just need to file off about 0.5mm from the underside of the adapter. You could file the top of the cart down, but why screw up that pretty metallic painted lettering? It seems to me that Grado took some pains to make their P Mount carts not to easily fit standard adapters at some point. I've got some older ones that slide right in--back when Grado marketing thought it was prudent to sell a "universal" cartridge. They also had P Mount carts with the 1/2" ears also--looks very strange, but no mount adapter needed. How Grado thought that was a good look, I'll never know. Can't imagine they sold many of them. However, you still needed to do something for the wires--little sleeves was the answer. Yick on looks and clumsy for adapting. Even now, they don't use a different piece for P Mount bodies, they just cut those ears off.
Later on, marketing decided to make the P Mounts more difficult to adapt (for anyone who doesn't own a nice flat file, anyway) by making them a smidge taller.
Yeah the other problem I had with the Grado Green cartridge they offered me for pennies was, that it lacked the stylus and I didn't find an easy replacement so I called the deal off completely :)
I actually fit p-mount version of Grado Gold in the standard adapter, had to file off about 1millimeter off the top of the cart. Now it sounds pretty good on my Hitachi HT373.
This is a VERY important note: Grado p-mounts have a large than average cart size, and it will NOT work with many p-mount adapters!!!
