Ilikevinyl
Cool Breeze
Purchased the new Grado ME+ mono cartridge a few weeks ago. The new Grado MC+ & ME+ mono cartridges are "True" mono, where your only hearing the horizontal (lateral) movement of the stylus. First I bought the new Audio Technica VM610 mono cartridge. Found out after reading about this cartridge that the two channels are wired together. It's just like pushing in the mono button on your amp. So I returned it after reading about the new Grado "True" mono cartridges. Listening to the Grado ME+ for the first time, I noticed how clear sounding the recordings are. Your hearing much less groove noise! Was listening to June Christy and Chris Connor mono albums, more up and close (intimate) vocals! Bass is full and rich sounding. The mono sound stage now has layers to each sound, more front to back depth to the recording. Only have about 8 hours on the cartridge, sounds better every time I listen to it! High frequencies seem to be getting more airy.
If you have a large mono record collection and your turntable won't hum with a Grado, then I HIGHLY RECOMMEND the Grado ME+ cartridge!
Grado will also make any of the "Woody" cartridges for mono too! Those should sound even better! Much more money too!
The difference between the MC+ & ME+:
ME+ = 1 mil elliptical tip. Upgraded generating system. Four piece cantilever. Gold color body.
MC+ = 1 mil conical tip. Three piece cantilever. Silver color body.
Both cartridge specs:
Frequency Response: 10-50
Principal: MI
Input Load: 47K
Output at 1KHz 5CM/sec. 5mV
Recommended Tracking Force: 1.5
Stylus Type E
Inductance 45mH
Resistance 475
Stylus Replacement: Yes
Weight: 5.5 grams
Here's the Grado Hum Database. To see if your turntable model will hum.
https://docs.google.com/spreadsheets/d/1k_Wr5zx-hcJ0as6wub8wIqsMu2a67DyLhzE8grJp9mc/htmlview
Grado will also make any of the "Woody" cartridges for mono too! Those should sound even better! Much more money too! The difference between the MC+ & ME+:
Principal: MI
Input Load: 47K
Stylus Type E
Inductance 45mH
Resistance 475
Weight: 5.5 grams
