Grado MG
ltbetty
Just thought I'd share as there is so little info about the Grado MG out there on the web. I acquired the Grado MG RS1 on a Thorens TD318 turntable quite some time ago and had inquired with a tech at Grado about it as I needed a new stylus. He informed me that I had an early "reference series" and recommended the 8MZ stylus (which I did). I've used it on many turntables since with wonderful results. The other cartridge in the photo, just acquired, is also an MG but with the "RP1" designation (a P-mount cart). Both are from around 1985. So for those out there who stumble upon this thread, test your MG with the old stylus (or if you're good with a multimeter even better) and if it's working properly, don't hesitate to put a new Grado stylus on it! Many turntables later, it's still one of my favorites!
I have acquired several Grados, including an early Gold cartridge. Even with a lowly Black stylus it sounds fantastic. Working on restoring a couple of Dual tables and after I acquire all the necessary components for those I plan on upgrading it to an 8MZ.
Hi, Could you please let me know the shape of the stylus. Is it bonded or nude ? Thanx
Is the Grado MG a MM or MC cartridge?
What attributes would you recommend for a phono stage to make the output for a Grado MG appropriate for Line In use? Feel free to recommend specific devices if you like. I am looking neither for ultra-cheap nor stereophile level stuff.
EXPLANATION: I am trying to set up a system for my daughter and have pulled out an old TT equipped with the MG. I also bought a streaming device, but find it necessary to use it's Line In not realizing this required a pre-amp.
The ART DJPREII Phono Preamplifier is a decent inexpensive preamp that would work for you. The MG is a mm cartridge (actually I think technically a moving iron cartridge). Pro-Ject also makes a decent, inexpensive phono preamp. Hope that helps.
