Grado Opus3 review
Right, but I meant compared to the other wood bodies.
View attachment 2033063View attachment 2033063
Okay, here’s my best photo. Pretty much think it establishes the point, so to speak, is bonded.
I have been a close personal friend of John Grado since my father and Joe Grado best of friends. John has at times made cartridges especially for me maybe this one he made for me with a nude stylus but from what I understand the Woody's are nude
My Platinum was bonded, but sill stellar.
It's not just a shorter wire. They are two different gauges of wire entirely. The high output has finer guage wire and waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay more turns.
I agree on the Opus3. I've got the high out. I can't really see the point of getting a low out since, as Wolfie says, the inductance in either case is already so low.
Speaking to the high output: I can't believe what Grado was capable of doing with the bog standard bonded elliptical and aluminum cantilever regarding how it sounds. Tracks great, does everything I can think of on my list superbly well. I haven't heard the 3 series Prestige cartridges but it leaves even the 2 series behind which left the 1 and the 0 series way behind. I can't see a retip bringing more to the table except for longer wear that a line contact will give you. I have taken it off my table and put it on again and again. I don't want to believe what I'm hearing and I would like to know what fundamental changes Grado made to get this new trick out the old dog. I've heard all the Grados there are to hear and this one sounds like they do after a high quality retip. Could it all be just because of the maple body?
I grabbed mine off of ebay. Somebody, who for some inexplicable to me reason, decided not to keep it and put it up with a ridiculously low BIN. My thumbs jumped to action and bought it before my brain even comprehended what I was seeing on the screen. I didn't start as I usually do with low expectations, either. I was very satisfied with the 2 series and I was expecting more of the same, which isn't a low expectation at all.
I put a record on and my jaw dropped. The highs are so clean and detailed, the mids are always the Grado mids, and the bass is actually tight. Grado went after the issues of their cartridges with a surgical knife and figured out exactly what the problem was. The question now to me is how to fight upgraditis. I'm not usually one to do that, but if what I have is just the Opus 3, what does the next one up sound like??????????????
The high output wire is not thin at all, also the low output does not seem thicker to me, we are talking such a short length anyway it wont make any difference, think some of the best MC use 8 or 14 micron wire, gauge is a non issue. Also the inductance of the high output is low enough not to matter.
Chris
The higher ups weight much more than Opus3 which might cause compatibility issues. The wood type,cantilever and stylus profiles improve. To match the Opus with a Prestige3 a xtz stylus is the way to go.
I have not seen anything written by Grado to say there is any difference with the Opus stylus tip than any other carts in the range. Also bonded is heaver ie higher moving mass which is why I have been retipping them, that and a far better stylus profile.
Chris
They are not you are mistaken only the higher ones are, not the Opus.
Chris
The wire in the bodies isn’t the same wire between the high and low output of any Grado cartridge.
That is true. The hi outputs have 6000 turns of wire with a length if 125ft. The Lo have 360 turns in 7 feet. The hi uses #47 wire the low #35
Also when I put a microridge on a blue the difference is staggering, it made me realise what the a Prestige can sound like. I have both retipped the original diamond and replaced the last section of cantilever (part 3 IMO part 4 according to Grado). I leave an aluminium cup so the retip is actually another part so it now becomes 4 part or 5 part if I am missing something, probably why the expensive woodies are supposedly 5 part as the last boron bit is fitted as I fit it so Grado count this part. I am told in the past Grado used to have a telescoping cantilever ie front but slid over another tube, this is no longer the case so I think now despite advertising all Prestige are 3 piece and the better woodies are 4.
Chris
How did you get a microridge on a Grado? I've believed for the last few years that the ideal cartridge would be one that sounded like a Grado but tracked like an AT.
No it is not, the old AT95e was 0.4x0.7 the newer AT95e and the VM are all 0.3x0.7, I have instructions here if you dont believe me. Also I have looked at the tips under the microscope they are identical to the Grado.
Chris
Fact is, there are only a handful of OEM stylus manufacturers in the world, and most cartridge companies source from suppliers like Namiki, Fritz Gyger, and Ogura. As you obviously know, most buy the cantilevers and styli pre-assembled, then mount them into the cart or stylus housing.
Chris
Which is part of why I'm a bit wary of some of these products. I care about stylus profiles and bonded vs. nude because there's a noticeable difference between how the two handle the difficult inner grooves (especially) of my classical records. A bonded stylus just isn't really good enough for me anymore. I'm glad that the Opus3 is a good cartridge (there's a needle drop on YouTube with the Opus3 on the Schiit Sol and it sounds really great), but I don't know that it would really work for me. I wish Grado would vary their stylus profiles a bit. I am interested to try the Sonata, which I know has a nude stylus.
Not sure what you are saying but a MC has the coil on the cantilever which is very thin wire and a MM or MI has it in the body and much thicker (Grado). If and I say If a the Opus has a thicker wire it makes no difference as the wire is many times thicker than it needs to be look at MC and even high output MC.
Chris
I retip carts, I have removed the old stylus tip from a Grado and retipped with a nude microridge and I regularly do a different retip which is boron cantilever with nude microridge, the latter is easier to do. Retipped Grado sound amazing.
Chris
Chris
i can vouch for that. :)
Grado does everyting in house in Brooklyn. At times they have sourced from Tonar (Nagaoka)
Grado dont make the diamonds, all cart companies buy from others, I buy retip stuff from Namiki as many cart companies do, I can buy diamonds or cantilevers with diamond fitted, I buy both.
It is my opinion that Grado are buying diamonds and fitting to their cantilevers as there is a lot less glue than there is on AT stylus, but the tips looks identical.
Chris
