Sorry to dredge up an old thread, but it seemed precisely relevant so rather than start a whole new one..............
I took delivery of an Opus 3 a week or so ago, mounted it on my ADC LMG headshell on my Jelco SA370H tonearm, with damping dialled to 'Max'. This is connected to an Atoll P200SE phono pre, then through a Primare I22 class D amp. My immediate reaction once the needle landed was that, compared to the AT VM750SH which it replaced on that arm, the overall sound was noticeably rounder and fuller, but the top end was 'tamed' particularly and especially for vocals, which sounded very closed in. Now I know that to some extent going from an AT cartridge that's to be expected, but this wasn't subtle, on some records the vocals sounded quite veiled and dare I say it a bit dull. The other thing I noticed was that it's much quieter than the VM750SH at the same amp volume (more on that later).
So I looked at compliance - the arm and headshell together is 17.6g, which I know is at the top end for the weight of this cart, but with the damping I think it shouldn't be a gross mismatch, and it plays well on my most warped records, and tracking seems fine - certainly good enough for listening to records pleasurably without obsessing about 'torture tracks'.
The Atoll has a number of user adjustable settings: Gain 40, 46 or 52db, Loading 47k or 100 ohms, Capacitance 0 or 100pf (capacitance should I believe be irrelevant on Grados). Given the Opus 3 I have is (supposedly) the High Output version I initially left the settings as per they'd been for the VM750SH - 40db, 47K and 0pf.
I had set the cartridge exactly perpendicular for VTA, so I tried it a tad 'tail-up' - no difference, still veiled. Next I tried upping the gain to 46db, and this did seem to improve things slightly, but to my ears there was still no sparkle in the vocals. And still it was a bit quieter than the same tracks played using the VM750SH (I wanted to make sure my ears weren't tricking me so using Audacity I compared the Opus 3 playing to rips I'd made of the same tracks with the VM750SH). So I upped the Gain to 52db, and this time things were much better, but there's no way I'd describe the sound as crisp or sparkling or sharply detailed. Certainly there is detail, and on jazz and classical it sounds really nice and smooth, and instrumentals are excellent, but still the vocals seem a little flat - is this the 'Grado' sound I'm hearing? Also, it seems strange that at a gain of 52db the Opus 3 is only slightly louder than my VM750SH was at 40db (given on paper the output of both is the same at 4.0mV). Is it possible I have a Low Output version by mistake? And if not, is there any issue running a cart at significantly higher gain than it should need?
I'd certainly like to keep this cartridge because overall it really gives some body and heft to the sound, so if I can get it to open out a bit more I think it would definitely be a 'keeper'. It's also one of the quietest carts I've ever had in terms of groove noise, which is another reason I'm inclined to stick with it. As such, what do people think, is there anything else worth trying in terms of set-up tweaks, or is this just to be expected from a Grado cart?
