audioclassic
I am in the process of reworking a Grado wood arm for use on a Rek O Kut project. The arm has been disassembled, everything cleaned up and ready for reassembly and install on the table. One question I have: The arm has a notch at the back that rests on a horizontal rod inside the aluminum housing. All the photos I've been able to find of original appearing arms have a notch as opposed to a hole bored through them that the rod passes through or sits on. • Is the notch correct or was this originally a hole bored through the arm for the rod to pass through?
Is the rod glued in the tonearm notch/hole?
This arm was repaired many years ago. The repair was done well and the screws are almost an improvement as reinforcement to a weak spot in the arm's design. I can leave this as is or repair it if a through hole is actually correct. But still need to know if the rod was glued in place or not.
