Jxmos
Member
At an auction last fall, I was lucky enough to win a Gray Research amplifier and preamp. Since information on these is hard to find, I thought I share what I’ve found and see if others might have more details.
As I restore them, I believe these are units from a console that Gray Research sold in 1956 called the ‘Concert Duet’. I’ve found references to the Gray AM-50 being sold as a standalone amp as well. The Mullard EL34’s appear to be original and are still test very strong. Since these are metal base examples, I’ve set them aside while I restore with other more common EL34 tubes. Unfortunately, the rectifier was bad and needed to be replaced, but that may have saved the output tubes. I founded the amplifier with a 20 AMP fuse installed instead of a 4 amp. It’s surprising that the transformers are still good, but they seem to be working well so far.
The Gray AM-50 is a clone of the Dynaco Mark2 with a few variations. Although I don’t have a schematic for either Gray unit I can see the amp is an early design of the Dynaco Mrk2 amplifier.
The Gray transformers are marked on top. The power transformer is marked TR-5000 while the output transformer is marked TR-5001. I assume these are Dynaco transformers since the wire colors match the Mrk2 schematic. Most of the red colored wire coming from the transforms has faded to more of a yellow color. Other than that the wires and connections are a match.
The PCB is obviously a Gray manufacture part and it’s mark with “Gray Research and Development Part No. PC-0001-B” on the solder side. All the eyelets and jumper wires match the Mrk2 PCB.
There are early schematic versions of the Mrk2 that did not include a cathode resistor. That’s the case with the Gray AM-50, it didn’t have a cathode resistor either. So I’ve added a 12 ohm 1% 1W resister for measuring the output tube bias. I’ve also updated the 1.2 M ohm to a 1.5M ohm resistor attached to pin 7 of the 6AN8 tube.
The rectifiers are different between the two amps. Gray used a 5AR4 while the Mrk2 uses a 5U4. The Gray also has a different filter cap design. I’m wondering if I should change the Gray design? For the first filter cap, Gray used two 40uf 350v caps in series with a 100k ohm resistor across each cap. This is effectively a capacitance 20uf 700v I believe.
The Mark 2 used one 30uf 500v cap with no resister (Mrk3 with its 5AR4 has no resistor either)
So, which is the better filter design for a 5AR4 rectifier? Two 40uf caps in series or one 30uf cap?
The AM-50 is working. All the components on the PCB were out of spec except the two rectangular caps. I've restuffed the quad can cap with new 20uf 500v capacitors. The 2 40uf 350v caps are original but I'm checking them frequently.
The amplifier is wired to supply power to the Gray mono preamp and I’ve just started looking at this unit. The preamp doesn’t appear to be a Dynaco clone but maybe a Heathkit WA-P1 clone. The only marks on the Gray PCB are PR-1. I’ll need to spend more time tracking connections to see if they match. Another bonus, the preamp came with 2 Telefunken 12AX7 ribbed plate tubes.
If anyone has copies of the schematics or manuals for the Concert Duet, AM-50 or the Gray preamp, please let me know. Also, please share your thoughts on the filter caps.
