Scuzzer
Fixed Bias
Because ABX test have 'proven' that all amps sound the same.
No they haven't. There are generally tons of caveats surrounding amp statements regarding the design and specifications.
Obviously a low powered SE tube amp and a high powered 70s receiver are most likely going to sound very different from each other. If the two amps measure the same (I'm talking distortion spectrum and everything) then they might have a chance of failing an ABX. The speakers play a role here so the measurement into a passive resistor load might not be what you get with an active speaker load.
