specialidiot
Break Glass, Smoke Lucky
I picked this up from a local AK guy, your basic EL84 PP amp. All the AX7's are Telefunken, as are the rectifier tubes. EL84's are labeled Grommes, Made in USA but unfortunately one of them disevacuated on me so I stuck in a similar looking RCA.
Sounds pretty good, but not quite there. A little research shows that 50 year old Tiny Chief caps should be replaced, so I spent last night doing that.
I found some replaced resistors, one of the 'lytics below replaced, and I think the bigger mulit-section FP is new. Anyone know how to read the date codes?
Also, I thought these were all factory built but they must have had a new guy on the soldering iron, there's way too much solder on nearly every joint.
All the Tiny Chief's are replaced with 716P's, and I cleaned up the pots and switches. It sounds a lot better.
Schematic here.
Schematic here.
